fraz101
I plan on cutting my carbon steerer tube on my giant tcr pro.
I have read some conflicting advice on what to do. Here are the opinions.
1) if I want to remove 20mm of spacers I cut 20mm of tube PLUS 3mm extra for the expander plug which will sit on top.
2) If I want to remove remove 20mm of spacers , simply cut 20mm off the steerer as the extra 3mm will already have been accounted for on the initial set up.
3) if I want to remove 20mm of spacers I should remove 15mm of tube and fit a 5mm spacer above the tube before I tighten the top cap.
Opinions please!
Opinions please!
