Carbon seat posts - worth it?
PaulSecteur
No longer a Specialized fanboy
I have a Secteur, and generally Im vry impressed by it. The only slight niggle (and it was slight) was that the seat could do with coming a bit further forward than the lay back seat post would allow. I have now change it for a zero offset one from halfords for £15. Now that I have the seat more forward the spongy bits of the saddle are comfortably under the boney bits of my arse. To be honest, Im happy with it, but as I was researching the seatpost I came across carbon ones, and specifically the Specialized ones with the zerts inserts that are supposed to have more give and and like carbon forks, cut out the buzz.
So far on my 20-30 mile runs I havent had cause to complain, but I do plan to up the mileage and despite the price (£90 new, 50ish of the bay) I see it as something I can keep and put on different bikes... But only if they are worth it.
So, Do carbon seatpost make a difference (Especially the ones with Zerts)?
http://www.specializedconceptstore..../S-WORKS Pavé SL Zero Offset Carbon Seat Post
Garz
Squat Member
Down
I bought a cheap one from planet-x and where it met with the seat clamp system it freed so you could spin the saddle. After discussing this with the man from planet-x we came to the conclusion that unless it's an expensive carbon one then your best sticking to something metal.
Gerry Attrick
IMHE, carbon seat posts can make a difference in that they may in certain circumstances calm the buzz felt by your rear. However, there are so many other variables relating to frame material, tyre pressures, frame design, seat post exposed, seat post diameter, a**e sensitivity etc. that there are no guarantees other than by riding your chosen post.
