Anonymous1502
I got one of the pedals off no problem while the other one won't budge.
I have one of those spanners with adjustable width I am definitely doing it the right way.You might need a bigger spanner !
Thanks I will spray it and see in the morningCommon issue. Give it a spray with WD40 and try again in the morning. Otherwise you might need a longer pedal spanner, something for more leverage, or more brute force Involving a hammer!
It's the right one and I am doing it anti-clockwise.As above from @fossyant check you are trying to turn the correct way
I don't have a hex key.Check if there is hex key socket at the end of the thread on the inside of the crank
I don't have a pedal spanner eitherI used greater leverage by standing on the pedal spanner, worked a treat!
Are you using the adjustable the correct way round?I have one of those spanners with adjustable width I am definitely doing it the right way.
Put gears to lowest ratioI used greater leverage by standing on the pedal spanner, worked a treat!
