Custom24
- Oxfordshire
Hi
I have a Specialized 2012 (or maybe 2011, not sure) Hardrock disc.
Freehub removal was going swimmingly until the bit where I need to insert the 10mm hex key and remove the actual freehub body.
The problem is that the key doesn't fit. Not sure if I need to insert a hex key from the other side (none of the ones I have fit), or if I need to use a splined key - there are what look like splines in the freehub body.
I don't know the model of freehub on there - the docs that came with the bike say Shimano FH-RM30-8, and that's what I have to replace it with, but I think that's because the docs are for a Shimano rear drive system as a whole, rather than the individual components which were used to build my bike. And the Spez website doesn't say what model of freehub is used.
So I'm stuck...
Thanks for any suggestions.
Mark
So I'm stuck...
Mark
