Jon George
Mamil and couldn't care less
- Suffolk an' Good
The gory details:
Chain gauge tool suggests new chain, but not enough wear for a new cassette.
Front mech is a triple with an eight speed cassette. The LBS did not have a 8-speed chain in stock, but said a 9-speed would still work. (It turned out I had a new 8-speed in my 'stock', and I cannot discern any difference between to the problem that has presented itself.)
When I put on a new chain and the bike is upside down so I can attend to it, I can run through all the gears. When I go for a ride, however, I cannot engage the top chainring. This happens with both the new chains. If I adjust the tension so that it will engage, I cannot then disengage it.
I have:
Checked the cable; it's fitting into the handle bar gear change; and the smoothness of its run to the mech.
Checked that limits on the mech are adjusted correctly.
Put the old chain back on and it works fine.
I appreciate that a new chain (and I have replaced the chain on the this bike several times before) will be stiffer, but what the hell is going on? Do I need to put on a new cassette, as well?
I have:
