I know it is best not to, but this is what I want to do: My daughter's 80s Raleigh mixte has ordinary old shifters on the stem, a six speed cluster and a nondescript Raleigh rear mech. (I am going to abandon the front mech as she never uses it). I want to leave the back end alone, because any changes there will need quite a lot of work. I want to fit an Alvio 7 speed index clicker. It will only be allowed to move six clicks, stopped down by the rear mech limit screws. I know the gaps between the cogs will be slightly different from the movement allowed by the clicker. But will it be a significant difference? Will I have trouble getting good chain alignment in each gear? Or does it not matter all that much?
The reason for leaving the back end alone is that the six speed cluster is a bit of a bastard design, and the hub is designed only to work with this unit. The inner five go on like a cassette, then the last one screws on to keep the other in place. If I want a different cassette, then I'll need a different wheel, by which time I might as well be looking at a different bike.
