Can I use this frame to build a road fixie?
Yes, if you want to.
alecstilleyedye
nothing in moderation
if by road tyres you mean mtb slicks then yes, if you mean 700c wheels with 23" (or 20, 25 or 28) tyres, the answer is no as the frame geometry is wrong.
tyred
Ireland
My advice would be to look for an old ten/twelve speed "racer" frame, preferably Reynolds 531 but I wouldn't dismiss a lower end one if it's in nice condition and cheap.
Gower
As a 'Golden Oldy', I find the current fixation (pun intended) with fixed wheels a bit bewildering. When I was a lad (groan) and getting in from school and needing a bike to go out and play, I usually lashed something together from old bits and always had a fixed wheel because we could do more stunts (riding backwards, sitting on the handlebars etc.) and didn't use brakes. The other reason of course was that a fixed wheel bike was the simplest to build and had less to go wrong. In later years, a lot of my pals would put away the 'good' bike for the winter and use an old hack, invariably fitted with a fixed wheel, in order to save wear and tear on the 'new' Simplex gear. Not much new under the sun, really.
Cheers,
Gower
