it depends on whether you short drop or long drop brakes. i can't tell you what you need. but the tiagra are short drop, and may not reach the rim if you need long drop
hmmm there is no difference in the drop between that and the tiagra from the looks of things! but I will take your word for it that tiagra is short drop and will not reach accross the 64cm..... cheers
The alternative to modifying an old frame to take recessed nut brakes is to look for some modern nut and bold ones. These offer very long drop and use a nut and bolt. You should measure the drop you need before buying though.
