Can I fit a 34T ring on a regular chainset?
swee'pea99
I've never really understood 'compact' v regular chainsets...I have a 52/39 setup (I swapped a 39T for the original 42T to get a lower gear) - would a 34T ring would fit on the (Ultegra) chainset? Or would I need to change the whole thing? One other thing, if I could get a 34T ring to fit, are they all standard, or do, eg, Shimano & Campagnolo have different fittings? Thanks.
With compacts the arms shrink slightly to keep everything in proportion - so the space between the bolt holes is a bit shorter.
Specifically, the BCD for a standard Shimano double is 130mm (measured from the centre of one bolt hole to the next with a ruler and multiplied by a fraction as per Sheldon http://www.sheldonbrown.com/gloss_bo-z.html).
The BCD for a Shimano compact is 110mm. So a normal compact chainring won't fit on the standaDrd cranks.
Campagnolo have a different fitting (BCD = 135mm) so they won't fit.
As Adrian says - a 34t won't fit.
PpPete
Chandler's Ford
You need to look around for a 130BCD 34t chainring .
Sadly - such a thing is impossible. The bolts would be outside the teeth!
130 BCD - 38 teeth is the smallest possible as Adrian says
135 BCD - 39 teeth is the smallest possible.
Another way of getting lower gears (if your mechs and shifters will handle it) is a converter ring to make your double into a triple.
swee'pea99
swee'pea99
I'll take that as a 'no' then! I kind of suspected as much, but thanks for the confirmation. Back to the drawing board...
al78
Horsham
If you want lower gears, could you change the cassette to one that has a bigger sprocket as its bottom gear?
swee'pea99
swee'pea99
Fair point, but as it happens it's only the bottom end I'm interested in right now. I'm doing the etape in a month, and I need some *low* gears! As it happens, I spent today filing down the jockey wheel teeth on my rear mech, to stop it interfering with the 32 tooth on the MTB cassette I just fitted. It worked too! I think that'll do me. Any lower and I could climb trees.
swee'pea99
swee'pea99
Well, yes & no. Mostly no! And I do appreciate help. Even if it didn't directly sort my problem this time, now I know about B screws. It all comes in handy in the end...
