Can I change to BB30?
Doyleyburger
NCE West Wales
I am in the process of slowly upgrading a few bits on my defy 4 and was wondering whether I could change my internal square tapered BB to BB30. Obviously I would need a new crankset but would like to know if ......
(A) my frame will take BB30 ?
And (B) would it cause a problem with my current 8 speed cassette if I put a new crankset on?
Thanks
TheDoctor
The TerrorVortex
No, you can't. You can go from BB30 to other things, but not to BB30 from other things.
If you're going to upgrade things I'd start with wheels and tyres, personally.
Crankset would be near the bottom of the list.
TheDoctor
The TerrorVortex
Check this out.
HT2 uses outboard bearings and a wide-ish axle that's part of the chainset. The other crank goes on with 5mm bolts. I run some bikes with HT2, some with square-taper. TBH there's not much to chose between them.
