I believe it to be British as the bottom bracket has left and right hand threads, the vertical chain stays join the top of the seat tube in the fast back stile. The drop outs are Campagnolo, the left hand side rear drop out has the number 6410 stamped into it. Could this be the year it was made? [ October 1964 ] No other numbers are on the frame. The forks are Zues 2ooo, and they have a Colnago club cut out on the top of the forks crown, this is also cut out on each side of the seat post lug. Along with the club shaped cut outs, the seat post lug has a heart shape cut out of it on the top of the cross bar section. The two head tube lugs on the tops also have the heart shape cut outs along with one under the down tube of the bottom bracket.
There is one cable stop for the rear derailleur gears brazed on bottle lugs and a approx. .30 x 5 mm piece brazed on to stop the gear leavers from moving. The rear brake cable must have had cable clips.
