- the post-brexit wasteland
i've got 19mm mavic rims on my commuter. they came with 35mm gravel tyres which i switched out for some 23mm rubino pros which i basically wanted to get the use out of. been running them like that for the past month.
last week, the rear punctured repeatedly, all on the rim side. suspecting a rim tape failure, i replaced the cheap and nasty oem rim tape with some velox, but still got the same problem. in frustration (and having run out of tubes), i put the 35mm tyres back on.
the front tyre was ok; i tend to run 120psi at the rear and 100 at the front with the 23s; was it just that the rim could not take 120psi without causing the tube to puncture? the 35s are 65psi max…
