Campagnolo hub dust cover?
The_Cycling_Scientist
Cambridge
Hey guys and girls...
Other day I was gunning it along on my fixed gear and the chain jumped off between the frame and the hub.. Problem is it's chewed up the dust cover on my old 80's hub :sad: I'll attach a photo to show the problem. Question Ive got is how easy will it be to source a replacement?
Loch side.
That ain't no dust cover. It is a labyrinth seal.
It doesn't look damaged enough to worry about. Leave it. Removing them inevitably causes more damage than what you are trying to undo.
Cambridge
Problem I've got is it bent out of shape snd doesn't hold in place so it's prone to coming loose whilst in motion and the concern is dirt getting into the bearings. Could this be a problem?
Loch side.
Yes, it would be a problem. The trick now is to remove it and to try and reshape it so that it fits flush and tight again. Otherwise just stick it in place with silicone, making sure the silicone goes nowhere else than between the outer edge of the cup and the hub's cup seat. This way you can remove it again but it will stay in place. An open bearing is not a good idea.
