Campagnolo Cassette/Rear Derailleur compatibility
Merida man
Regular
I have a 53/39 14/27 on my Campag 2000 Bianchi Road Bike. I'd like to change the rear Mech set-up and cassette to make it easier to get up hills. My fitted RD is a Campag Veloce 9 speed SS and I would like to change this and compatible cassette. I've found a 9-sppeed Rear Mech on ebay but cant find any Campag Cassettes for 9-Speed beyond 27 sprockets (looking for at least 30). I know I can't use shimano cassette on Campag Rear Hub so what are my options. Many Thanks
Spiderweb
Not So Special One
North Yorkshire
12-29 Miche Primato Campag fit is the biggest I can find.
https://www.tweekscycles.com/miche-...1_1580298947_74cf37a1a778a7baf325af8f2ae99a7e
Cycleops
Accra, Ghana
Campag don't really do low bottom gear cassettes. Too cissy for those macho Italian men :smile:.
Your best option might be to find a triple front chainset but might be pricey, plus you'll need new FD and shifter. No, forget it, cheaper to lace a new Shimano hub and use their cassette. You can keep the RD.
boydj
Paisley
You have to get to 11speed before shimano and campag cassettes have the same spacing. You would be better to fit smaller chainrings, or, as advised above, a triple chainset, which would probably also require a rear mech with a long cage.
Loch side.
Campag made a nice system specifically for this problem. It was called a Racing Triple. The crank had three chainrings (50/40/30 or 53/40/30) and the rear derailer was slightly longer and could handle a 28-tooth cassette (perhaps bigger, I can't remember).
Merida man
Merida man
Regular
Thanks for all the replies. It's given me a few options and at the end of the day it's all a bit of cycle knowledge That I didn't have. I'm actually looking at this for a friend so I'll offer him some options
53/39 always gives gears of a tallish nature, in my experience. Might the simplest option be to change the cranks and chain-rings for a modern "compact" at 50/34? 34/27 is what I have as the lowest gear on my winter Sempre, and it gets me up most things, albeit slowly.
2old2care
Get a Shimano wheel and a Shimano cassette. The nine speeds are the same spacing for Campag and Shimano, so should work.
boydj
Paisley
Last year I made changes to two of my bikes to lower the gearing to suit my advancing years and diminishing power. With the carbon bike, I went sub-compact - 46/32, which is pretty much a cycle-cross set-up. With the other bike, I bought an old-fashioned square taper bottom bracket and a basic triple chainset - 48-38-28, which is more of a touring set-up.
I found Spa Cycles gives the best set of options to get a chainset with the right options for what you want without breaking the bank.
