Arch
Married to Night Train
- Salford, UK
In the last couple of times I've wanted to use it, my ATC has been playing up. Sometimes, no matter how hard I push, the on switch won't work, and then it does, and then doesn't, with no apparent reason (fresh batteries etc) And once or twice, once it's on, the record button also doesn't resgister. As far as I know, it's not got wetter than normal or dropped (well, I droppd it this morning, but was doing it before, and is the same now...)
Anyone else had problems? Bit annoying if I have to send it back or anything...
Esp as I dropped my stills camera (well, it was balanced on a chair and slid off) and broke the slidey lens cover that turns it on and it was going to be a minimum £80 for Canon to fix, IF they could, so I just had to buy a new camera..
But I have a new camera
. You could clean the battery contacts but it's also possible that disconnecting the battery works in the same way as switching it off and on again making it work again, especially if it only works for one go before getting itself into a state.
