Can you let me know whether you suffer from the same as me? I have a road bike with Ultegra level hydraulic discs. It's done about 300 miles. When I brake on any descent the pads rub for about 10 seconds afterwards and then stops. This can only be down to heat build up, but bearing in mind we are only in Spring and it's not particularly warm it's worrying what it's going to be like in the summer.
I've centred the rotor to the caliper, cleaned everything including the Pistons, the rotor is pretty much straight and there is a gap either side of the rotor.
Two bike shops have told me they all do this and can't be improved, is this right? If not what can be done?
Fairly new to discs and already starting to regret the switch, bearing in mind I'm a bit OCD about bike noises.
