Jordan Beddows
Member
- Shropshire
A few weeks a go, I asked what type of brake blocks I should use with my old weinmann brake calipers. I was recommended Kool stops. However, I would quite like to put new (Decent) calipers on to replace the old plastic ones, So I was wondering, What do you all recommend? I don't need anything special, Just a caliper that will do the job, Is reasonably priced and are easy to fit/set up (Still new to this ) Or, Should I just make do with the weinmanns and put a decent set of blocks on them?
Thanks!
Thanks!
