Cable through steel frame?
3narf
For whom the bell dings
Tetbury
I'm renovating a steel singlespeed bike, and was looking at the possibility of removing the ugly cable guides on the top tube, and routing the rear brake cable through it.
Is it advisable or even possible? I don't want to weaken the tube unduly. I assume there are some frame grommets available to keep the weather out...
Ta
And
Fun sponge
DE4, Derbyshire
It is possible, but to do properly is not necessarily an easy task - here's one way:
http://noviceframebuilder.co.uk/personal-articles/internal-top-tube-cable-routing
S-Express
Remove the cable guides, and put a cable boss underneath the top tube at either end, then run an open wire between them. Much neater. Unless you run a tube internally which is brazed at both ends, then grommets will never guarantee a proper seal..
mcshroom
Bionic Subsonic
Not sure this helps much, but I like the look of the cable running along the top through those guides.
However the picture makes it look like that frame is bent
3narf
3narf
Tetbury
Yeah, it's just the camera. It's definitely not bent.
Always thought the cable guides looked a bit of an afterthought...
3narf
3narf
Tetbury
Thx all, it doesn't sound like something I can be bothered to do as I think the cables will emerge almost at 90° unless I drill them oversized or file them into an oval.
Slotted guides below the top tube would look OK...
