TimDanaher
- Köln-Höme öf the Öther 'Dröme
Hi all, I've just bought a frame that uses internal gear and brake cable routing. However, it looks as though I have to feed complete cable outers through the frame – I thought that there would be stops on the frame entry points and I'd just feed the bare wire through the frame itself.
So, the question is, can anyone recommend a source of outer cables to do the job? The ErgoPower cable set outers are already cut to length, and I've only seen Shimano-compatible outer cable on the websites I've looked at. Would it really make any difference using Shimano-compatible outers?
TIA,
TIA,
