CAAD10 Bottom Bracket
rockwild
Hi, everyone.
Can anyone tell me if this crankset would fit on a CAAD10: FSA Crank ?
And if so, what adapters would I need to get?
Thanks for your time,
Cycleops
Accra, Ghana
No idea but would depend on the spindle diameter matching that of your BB bearings. Says it matches Shimano and SRAM so if you are replacing either should be okay.
T4tomo
yes, but you'll need the correct bottom bracket. you could start my measuring the spindle of your existing crankset, if that's 19mm then you're probably in business.
