Moby Jones
- Inverclyde
I am a bit frustrated with the gears on my 4 month old caad. I had a problem with the chain jumping off the small chainring so i took my bike to the LBS. The chap was able to get almost all the gears working apart from two which are not right, the chain is catching on the front Derailleur. I am going to take the bike back on Friday.
When i bought the bike from Evans the chap in the shop mentioned something about using the gear selector to trim the gears.
When i took it to my LBS he said the gears had been set up incorrectly and he had made what he felt were the correct adjustments. Like i said everything seems to be ok apart from two gears which i use quite alot.
Does anyone have any experience of the gears on a caad8 double sora
