C2W scheme (again)
Soltydog
near Hornsea
I got a bike through the scheme at work last year (full £1k limit) & this still has around 9 months to run as it's an 18 month scheme, but they have opened the scheme up again.
I was looking at getting a hub geared hybrid in the winter & this seems like an ideal way to get one a few quid cheaper :biggrin:
Anyone know if it is possible to have two C2W agreements running together? I've scoured the net & cant find a yeah or neigh & cyclesolutions aren't sure either :wacko: Should I just apply & see if it gets accepted??
GrumpyGregry
Here for rides.
yes you can. one of my colleauges has exactly that....
Norm
Hmmm...
1. Why scour the net when you can go straight to the source? Section 3 says, specifically:
3) What value of equipment can be supplied?
There is no limit on the total value of the equipment including the cycle. It is possible to loan two cycles to one employee if, for example, that employee needed a cycle at either end of a train journey between their home and place of work. (However, please see Section 9.1 where the Office of Fair Trading (OFT) has advised that the group consumer credit licence will cover schemes up to a value of £1,000).
2. As is nearly always the way with these things, whether you can do it depends on the specifics of your scheme and no-one else on here can answer that one for you. :thumbsup:
Similar threads
