Buzzing Xenon levers
gbb
Peterborough
It's starting to do my head in :rolleyes: , vibration is rattling the levers on any rough tarmac.
My last 9 speed Xenon ergos started doing the same after 2 or 3 years, but these 10 speed ergos are doing it worse after only 6 months.
Any known fixes ?....i'm going to have a play tomorrow.
Joe
I've got a right Veloce lever that does the same. I sent it back to Campag and they did something (it had been opened, had fresh grease etc) but after refitting it I discovered it still rattled:angry:
I tried everything but eventually gave up and upgraded to Chorus.
Mine was like it from new too:sad:
Will1985
Norfolk
Is the rattle in the body or the levers? Before I took Xenon off it started to develop a rattle which I fixed with a little bit of tape and foam between the levers.
Tynan
e4
mine have started to do that and it is annoying, in fairness they're a bit cheap and nasty aren't they?
Tynan
e4
Lardyboy said:
Has the little rubber grommet moved or gone awol from under the brake levers? That's the most common cause of the "Campag Death Rattle."
ta
