Hi Guys, I am a relative newcomer to cycling, my last experience was in 2005 when I went over the handlebars at high speed with no helmet on. Cracked skull in 3 places, 7 x-rays on various body parts and 6 years later and I'm back on a bike this time with a proper helmet. Anyway at the end of last year I bought a new MTB with disc brakes. I have never experienced disc brakes before and none of my friends have any knowledge either. It may be nothing but when I am going at high speed especially downhill and I brake, there is a buzzing noise coming from the front brake disc its kind of like the noise that would happen if you put a piece of paper into the spokes of the wheel. It doesn't happen at all at low speeds or on the rear brake disc. Also occasionally there is a loud creaking noise again coming from the brakes at high speed so much so that I can feel the vibration through the saddle. Kind of like the noise and old bus makes when it brakes. Any idea what these noises could be ? I have taken it to Halfords where I bought it and they say the brakes need time to wear in, however I am probably on about 150 miles now. Also it has a quick release wheel which I am not sure exactly how tight to make it. If I make it as tight as possible the brake disc doesn't run smooth and there is rubbing between the brake disc and pads, too slack and the wheel will likely fall off. I'm a bit lost with it all and really don't know what is correct.
Any advice ?
Any advice ?
