Buying Second Hand
Danny91
Liverpool
There is much information on buying new bikes from retail lines etc, but what about buying bikes second hand?
I've heard of the likes of ebay,gumtree, preloved and local newspapers to find ones for sale, but what should be looked out for when buying second hand?
I am after a mens hybrid bicycle for road/trail cycling (may be on grass in parts) with £150 to spend - second hand is the only way for me really.
Thank you!
MontyVeda
if it looks right it's right.
if you can try before you buy then check the wheels are true, the brakes work, check the frame for dents/rust, check the weight, give it a ride round the block and check the gears. Have a look at anything which may need replacing such as old tyres, brake blocks, cables, etc and consider those as part of the total spend.
gbb
Peterborough
Hiya Danny :thumbsup:
If i were buying second hand, here's what i'd be looking at...
1. Spin the wheels, are they buckled or untrue ? A little wobble's probably a quick tweek up for a bikeshop.
Do they spin freely ? Let them spin to a stop, (making sure the brake blocks aren't touching) any sudden stopping or graunchiness indicates hub bearings need attention.
Stand over the bike, finger and thumb round each tyre and feel if there's sideways play, again indicates the hubs need attention.
2. Apply the front brakes and 'push' the bike forward. Any excess movement between the frame and forks , it incicates the headset requires attention.
3. A quick look round the frame, particually at the points where its welded...particually all round the BB, where the seat tube joins the crossbar, at all the joints, look for cracks. Very rare, but it does happen.
4. Look at the front chainset, are the sprockets excessively worn ? Look for a sharkfin effect. If they are, it probably means the chain and rear cassette are too. Worn transmission like this costs a fair bit to put right.
5. Preferably (certainly) test ride the bike, change through all the gears front and rear. TBF, if its difficult to select an odd gear, its probably just an adjustment thats required, but if they start skipping and over-running etc...it indicates worn chain, worn cassette etc,,,again, expensive to put right.
6. Tyres...are they ok ? Its easy to forget how expensive tyres are...£30 for a decent pair.
7. Wobble the cranks...any excess play ?
Don't be put off, there's plenty of hardly used bikes out there, brought by well meaning people who just don't get to use them much...but a wrongun will cost you.
Dave7
Cheshire
I have a very good hybrid for sale on here but no takers. I can understand that as CC caters nationwide and the seller (me) is relying on someone the same size(ish) in the right locality who wants what you/me are selling.
So I put it on Gumtree and sold it twice within a few days........but neither "buyer" turned up:wacko:
So if you are in the north west and are between 5'6" and 5' 11" then have a look at mine.
As a side note......if buying of gumtree you might want to get some type of evidence that it isn't stolen.......if it is and the frame No is registered you could end up losing the bike and the money!!
