Butterfly handle bars
Welshman
Can you put them on a gravel bike, a boardman. Would it cost much to get it switched.
I have a hybrid which is nice upright ride, thought I try drop bars, but too uncomfortable.
Twilkes
From memory, butterfly bars are usually a replacement for flat bars, not drop bars, and if you replaced them you might have mismatched diameters on the stem clamp and the shifters, and even if the shifters clamped tightly you might not find a suitable place to put them and be able to comfortably use the breaks and change gears. And the geometry of your bike might not make it a comfortable ride.
Before you do something drastic, try taking the bars off the stem, taking the stem off the back, and turn it over so it points upwards and the end is closer to you, then refit everything to your bike. You might find that much more comfortable if your drops are currently too low. It's worth trying to get used to them, I rode flat bars for years but wouldn't really choose to go back for anything other than errands or family rides.
Cycleops
Accra, Ghana
Could work for you but you won't know until you get them on. You'll have to replace levers and change other bits, won't be cheap.
If you don't like them it might turn out to be a wasted exercise, but might suit you if you want a more upright stance.
W
Welshman
I have put a stem riser on, but still get pain through my arms, and constantly shifting hands , is it just seat too high .
Cycleops
Accra, Ghana
Saddle height and bar height are two very different things. Your correct seat height should have your leg more or less straight when sitting with the pedal at six o clock. Plenty of videos on YouTube.
If you want a very upright stance the butterflies could well suit you as I said.
Maybe try to find some cheap ones used and just put them on to see how they feel.
iandg
I've just done 2 drops to flat bar conversions because of health problems.
On top of the price of the bars, parts that you (may) need to change are:
Handlebar stem - length and clamp size may need to change
Brake levers
Gear levers
Bar grips/tape
Brake and gear cables
Cross-check - I used the existing stem and tape from the old bars. I had V-brake straight bar levers in a spares box and all the cables and outer-casing.
On-one Jeff Bars, Planet X £30
Sun Race thumb-shifters, Spa Cycles £22 each
Henry Burton - I had thumb shifters, bars, stem and all cables
Shimano straight bar levers, Wiggle - £12 each
Ergon Grips, Wiggle - £32.50
Maybe too much weight on your hands ?
So higher stem or a shorter stem ?
What tyres do you have - what width and what psi are you using ?
Fredo76
Española, NM
