As I continue my restoration on my old bike I've now ridden to work for two days. Very steep hills and the brakes aren't great so planning an upgrade to some better pads however I've come up against another issue:
When using my front brake there is a jarring that is really intense when braking hard. It seems to be causing loosening of the brake arms. I assumed that the wheel needed trued but on closer inspection there seems to be a small bulge in the rim. The wheel (chrome) seems in otherwise decent condition but I'm not sure what my options are - could I tap this out with a hammer?
While inspecting this I noticed that there is more room between wheel and fork at one side than the other, I've checked the wheel nuts which had come slightly loose but it seems that the wheel isn't properly squared, only thing I could think of was the axle - or could the forks be slightly bent?
As always, any thoughts would be greatly appreciated!
All the best,
Matt
All the best,
Matt
