Cyclocross bike
My CAADX needs a replacement fork. Cannondale has a recall in place for my model after several catastrophic fork failures. I will get that done once I have been vaccinated but until then I am not going to venture out to bike shops a long way from here.
My cousin gave me his old Powercrank. The only one of my bikes that it will fit is the CAADX but that means that my helpfully low 46/34 chainrings will have to be replaced by 53/39. That will make the bike overgeared for steep local bridleways, but I have a secret weapon to bodge on - a 42 tooth sprocket! I'll have to remove one sprocket from the cassette and shift the others down one place to make room for
The Big One.
Once the Powercrank is working I will start doing regular rides up the long local Cragg Vale climb to see if I can get my power output up to a decent level.
Apart from that project, I have other things to sort out...
My sister has moved to Devon and has said that I can leave a bike down there. To my way of thinking, if I can leave one bike there then I can leave two! I'm thinking one road bike and one mountain bike...
Road bike
I have an old Al Specialized frame/fork currently being used on my singlespeed bike. I have to use a chain tensioner because the frame has short near-vertical rear dropouts. I don't like the chain tensioner, but I
do like riding singlespeed (on flatter routes as a change from using lots of gears to get over extreme lumpiness).
I have an old steel Basso frame/fork temporarily built into a stripped-down singlespeed turbo trainer bike. That frame has longer semi-horizontal dropouts so I managed to singlespeed it without using a chain tensioner. I think there is enough room in the dropouts to cope with some chain wear and I'd have the option of putting a couple of half links in and removing one when the chain got too long.
So, what I am thinking is to build the Specialized into a 3x10 bike for the hilly roads of the SW and build the Basso into a singlespeed bike for up here.
Mountain bike
My old 853 steel Rock Lobster MTB has been out of action with faulty Hope disk brakes for a couple of years now. My cousin donated some Shimano brakes which I intend to replace the faulty ones with. The whole bike needs a good going over and then that can go to Devon for Dartmoor exploration etc.
My cousin also plans to give me his Giant Zaskar MTB so that will become my MTB for here. He was going to bring it down from Scotland when he came for his annual Tour de Yorkshire cycling holiday last year but Coronavirus put a stop to that. Hopefully he can make it down here later this year once the virus situation finally starts to be brought under control.
I officially retire this time next year and the virus should not be a problem by then, so I want my bikes to be ready for plenty of 2022 OAP cycling action!
