simon_adams_uk
- SW London
Has anyone on here built a DIY cycle trailer?
I'm thinking of having a go and would appreciate some hints / tips.
The starting point for my design would be the Carry Freedom Y frame
(http://www.carryfreedom.com/Y-Frame.html)
My first thought was to replace the wheels with castors (eg http://www.toolstation.com/index.html?code=73821). Any obvious problems with using castors as opposed to wheels that I've missed? Is the suspension offered by pneumatic tyres essential?
The second major change would be to replace the metal Y frame with a simpler towing arm that is attached along the LHS of the plywood base. It could be made out of PVC waste pipe with a 135degree elbow in order to connect to the bike's rear triangle. There's some inherent flex in a waste pipe - good or bad? (I'm minded to say a cautious yes).
The connection between trailer and bike would be a combination of a standard 'D' shackle on the trailer and one of those old rear mech protectors clamped (effectively on the wrong side) by the QR.
[All in, the castors, plywood base, pvc pipe as towing arm should all come in under £30.]
S
S
