Oh sure, loads of this is far too open to interpretation, for reasons of crap data that I explain below. The article linked in the OP is doing it too, IMO.
Actually, I don't commit the population geography sin in that cartoon, because where I refer to "cycling levels", I mean the % of population who cycle (usually Active People Survey), which of course largely takes population distribution into account (not completely, but do people prefer to cycle in dense cities or open roads anyway? I doubt everyone on this forum likes the same thing and we don't really know what the population prefers... once again, it's complicated
Not exactly no difference. Merely that it's helpful but not sufficient. I feel you can't create mass cycling with infrastructure alone, but you can certainly suppress cycling levels by not providing any (especially if routes go through complex junctions that are hostile places to cycle).
Also, I slipped up and should have written "those places" or "the cycling-friendly new towns" or something like that: Stevenage, Milton Keynes and so on. Their problem is mainly that motoring was prioritised and facilitated to a point where it became a default choice, a habit: the town looks like you're expected to motor, so people motored. In the case of Milton Keynes, front-line promotional materials explained how to navigate by car (it was going to be N/S/E/W/C on the roadsigns, then as you got closer, you'd see the first part of the postcode on the signs, then district names within that postcode) but not by any other method.
The cycle networks of those towns may be good compared to the rest of England but still distinctly secondary, because even Claxton in Stevenage was probably working plans set out for motorists first. Claxton only became lead engineer there in 1962, 16 years after its designation as a new town, 3 years after its town centre opened, which doesn't quite fit with how most people would understand het Gruaniad's description of him as "lead designer of post-war Stevenage". Longest-serving lead engineer, possibly. But wouldn't "lead designer" make most people think he led the original design?
I suspect motorists-first was just ingrained in planners and designers of the era when the new towns were designed (1946-1970). It goes right down to little things like streets having name signs only where motorists can enter them and not where cycleways do. So in most new towns, you end up cycling up and down artificial inclines and being hidden in trenches or behind trees at the edge of the highway corridors, while the motorists generally get the flatter route, central portion of the highways and priority where the routes cross on the same level. Look at even the picture from the Ladybird book in the Guardian article: the NS motorways are straight lines, while the NS cycleway goes E along half a side of a square, then W along half the far side of it: "cycle priority route"? It doesn't look like it. It looks like cyclists are expected to travel the longer/harder route between two points, yet again.
Which bit? I'm happy to try to clarify.
Yes, most of the cycling data we have is pretty weak:
- Particularly bad for cycling is the way most towns/cities have traffic survey cordons set only on the A/B road entrances, while any cycle-only entrances (including cycleways alongside those A/B roads IIRC) are ignored.
- Automatic counters on cycleways are being left to fail and not repaired/replaced during council budgets cuts - and they only compare one point on one route with itself over time, not normally showing if cyclists have merely been diverted to or away from the counter by things like obstructions on the cycleway or the opening of a better alternative route.
- The Active People Survey gives a % of population who cycle regularly in a given area, which is a bigger number than the modal share or any counter, so I suspect it's probably more robust for year-to-year comparisons of the UK's generally low cycling levels, but it's still only a survey (so we can't get down below borough/district level safely IIRC) and there's no comparable Inactive People Survey with a motoring % prevalence.
- The National Travel Survey makes it easier to compare modes but again it's a survey and it's also biased against cycling by classifying trips by "main mode in terms of distance" so most bike-train/bus-bike and park-and-pedal trips aren't counted as cycling trips.
- The Census Travel to Work question covers everyone but only journeys to work and I think also misclassifies multimodal trips in the same way NTS.
Now I hope
@srw or someone will point out any bits of that I've misremembered, or other good data sources
Oh yeah, about the article's statistical sleights of hand - it doesn't say where it gets its town-level "cycling modal shares" figures from. Most often, "modal shares" means they're using traffic survey cordon counts, which always look worse for a town with many cycleways compared to one with few, for the reasons I mentioned above. The article also compares the "modal shares" of "some neighbouring towns" with the "% of the town’s residents [who] cycle each day" for Stevenage at one point, which seems rather naughty. In short, the article's number work is almost an innumerate mess trying to make the stats look like they support its central claim - it's far worse than anything I do
