ukoldschool
Hi all,
I had been carrying a multi tool and a couple of Allen keys/tyre levers in an under saddle bag, but saw an unused Brompton specific toolkit available on a well known auction site, so as it was cheap I took the plunge and I have to say I am glad I did! Its extremely well made, lighter than what I was carrying about before, fantastically well designed and best of all very neat in the way it stows inside the frame.
It is pricey, and I can understand people thinking "£50 for that..... (rrp)" but now that I have one I wonder why I didn't just stump up before as it really is a great little bit of kit and a fantastic design.
Here's what you get:
The cover of the case is alloy, and it has rubber ends with the bottom one being magnetic so that it 'clicks' into and out place perfectly, using the ring of the spanner to pull it out of its frame hidy hole...
- 15mm Spanner for the wheel nuts
- 2 steel tyre levers (one of which has a spoke lock and an 7mm M5 spanner, the other has an 7mm M5 and a 10mm M6 Spanner)
- On the other end of the 15mm spanner is a rathet drive for the following bits:
- Posi drive/small flat head screwdriver bit
- 2/6mm allen bolt bit
- 3/4mm allen bolt bit
- 2.5/5mm allen bolt bit
- Some puncture repair patches and a tiny bit of sandpaper
