Brompton rear triangle
Yellow Fang
Reading
Is it actually possible to separate the Brompton rear triangle? I was trying to remove the bolts so I could grease them. It has been making a horrible noise. The left hand bolt came out, but no amount of unscrewing would remove the right hand bolt. Then I put the left hand bolt back in and continued unscrewing the right hand bolt. This still had no effect on the right hand bolt, but it caused the left hand bolt to come out. I'm beginning to wonder if this is a design feature and not something wrong with the right hand bolt or thread.
ChrisKH
Essex
Good question. It is possible to separate the rear triangle as I've had mine replaced. How you do it is the real question.
Yellow Fang
Yellow Fang
Reading
Something was making a horrible grating, creaking noise. It was either one of those two pivots or the bolt holding the rubber block. Oiling them seemed to cure it before, but it tends to come back, especially when it's wet.
