As some may have seen in my wanted post I've managed to find a donor bike for my Brompton project, thanks again to @ABikeCam - I hope to get it back up and running and will document my efforts here
Here is the bicycle in question:
It has been stripped for spares so there are a few items missing which will need to be sourced, but before then I have a rather lovely set of cracks in the seat tube to try and deal with...
I've shown it to a few of my welder/fabricator friends and responses have ranged from "Ha, good luck with that!" to "That'll MIG up a treat buh..." so I'm not really sure what to expect, other than several hours of entertainment in the garage and plenty of peace and quiet for Mrs Bssll
One thing that I have read a number of times is never to try and weld a brazed frame, which of course the Brompton main frame is. I've taken this as a challenge and have bought myself a new toy
First job will be to strip it down and put the parts to one side, then I'll clean the frame up and try and align the cracks before trying to (very cautiously) weld them up, bit by bit, with plenty of cooling. No idea how that will pan out but I've got my lbs looking in to replacement main frame's if/when the worst happens and the brazing melts
I've sourced some brake bosses and am looking in to the possibility of replacing the caliper brakes with mini V-brakes. For no reason other than it would be a fun project. I've also got a cheap dynamo front wheel on the way, £75 new from eBay
It seems you can get fairly cheap coloured rims so I might look in to those when I've worked out a colourscheme later on - the frame will be getting a full rattlecan respray when I'm done with my tweaks
Anyway thats all for now, I'll post pics when I have had a chance to make a start. I sincerely hope I don't set fire to anything, it's been an awful long time since I've wielded a welding torch
Of course this means I will need to modify the spacing of the frame but I'll wait for the hub to arrive before I decide how to go about that. Hopefully I can heat it and stretch it rather than having to cut and weld but we shall see... Of course this means I need to keep an eye out for other bargain Di2 bits now and the alfine stuff doesnt seem to come up very often. Fortunately it'll likely take a while to get the frame stripped, repaired, modified and repainted so no pressure
