LCpl Boiled Egg
Three word soundbite
Hi,
My Brompton M3L is having some problems with the gears (Sturmey Archer hub). 1st gear is fine, but as soon as I change up there's noises from the rear wheel and the pedals slip now and again. It makes a sound like the gears aren't adjusted correctly, although I've checked the gear tensioner and that's OK, plus if I remove the gear cable completely so it's in top gear the same thing happens.
I thought it was the chain tensioner as the teeth on that looked very worn, so I changed that along with the rear sprocket, but that didn't fix the problem.
So, a couple of questions -
I didn't buy a new chain as the one I have isn't that old, but as I have changed the tensioner and the sprockets is it advisable that I get a new chain too?
If it's not the chain, could it be the chainring that needs replacing? I don't mind buying new parts, I'd just like to understand what the problem is first.
Anyway, if anyone can give me some advice that would be great. I hope there's enough information here, if not ask me some questions.
Cheers everyone.
Cheers everyone.
