I have the standard grips on my bike, but finding my palm is sore after riding. Can anyone suggest the best bar grips, and softest for old folk like myself please?
The Ergon GP grips are really comfy. GP1 has no bar end, while GPs 2-5 have varying lengths for even more hand positions. They all have the lovely 'wing' on the back of the grip which gives more of your hand somewhere to rest, spreads the load and opens up more options. You do have to buy the large size and cut them down by about 10mm with either a hacksaw (off the bike!) or Stanley, to ensure the fixing at the outer end has enough bar to grab on to.
No. The size refers to the circumference of the grips only, so is totally depended from the size of the hands. You had to cut them a bit on the old (pre-2017) M-bars with the old (pre-2013) brake levers. With the post 2013 Brake levers they are a tight fit but it is possible. With the new M-bars wit underbar-shifters from 2017 onwards there are no issues any more. On S-bars there has never been an issue.You do have to buy the large size and cut them down by about 10mm with either a hacksaw (off the bike!) or Stanley, to ensure the fixing at the outer end has enough bar to grab on to.
AgreedI think I have the Ergon GP3. I find them much nicer than the original grips.
It also depends on how old your Brompton is, as the factory have improved the grips over the years.
Kind of. They went from plastic to foam in 2000, from foam to somewhat thinner foam in about 2008, from thinner glued on foam to screwed on rubber in about 2017 and then to screwed on foam shortly after. They managed to improve from "absolutely catastrophic" to "totally catastropic" in 20 years. The grips are still the worst part of a stock Brompton in my opinion and the only part I exchange immediatly w/o thinking.
