Andy in Germany
I'm still getting used to Brompton gears. I've noticed a couple of things that seem odd:
1: I have a six speed system, and I get the impression there's a lot of overlap between the 'lower' and 'upper' gear set; it's not a matter of using the 'lower' set and cycling up thriugh the gears, then doing the same on the 'upper' set. Is this correct?
2: I've tried pitting a set of ergo grips on the handlebars and everything was fine, except that the grips are about 2cm longer, which seemed to putt the cables too tight and (again this is an impression) seemed to meke the gears run a bit rough. Has anyone else come across this or is it just me?
