PaulM
- Portsmouth, UK
These are parts which were replaced when upgrading from a 3 speed BSR Sturmey hub Brommie to the 8 speed SA hub by means of the Kinetics conversion kit. I doubt if I had exceeded 300 miles before upgrading. I'm selling these as a complete 3 speed kit.
The 3 speed kit consists of a standard rear wheel with standard BSR hub (pre-2013 so single walled rim), 13T sprocket, gear indicator chain and cable connector, 3 speed trigger shifter and outer gear cable, and chain tensioner assembly. Everything you need apart from a new inner gear cable since the original frayed. £70 the lot including postage.
SOLD Crankset is standard 170mm 50T integrated ring/guard. £30 SOLD
SOLD Pair of Stelvio HS350 28-349 tyres. Little used slicks (one 20 miles, one 300 miles). Came on a recumbent trike in 2008. £13 SOLD
