Our tandem has a oujimaflip ratchety thingamibob for gear cable adjustment.
The broken bit (I think this should be a full circle, not a semi circle), shown against 4mm hex for scale:
Should fit in the gap here:
I've never seen one if these before and even the tandem has a more normal screw adjuster on the other side:
So: what's it called and anyone know where to source a spare from?
In the meantime, the broken part is back in, held under tension. Don't want to rely on that in perpetuity.
