LordGrover
Regular
- Bristol
Went for first proper ride today - I'm excluding a couple of trips around the block and to the shops.
Basically a try-out of commute run, mostly cycle path and not too taxing; or at least it oughtn't be once I get used to it. On the way out I 'explored' a track which I shan't be using again, better suited to mountain goats and wellies. Stuck to the plan on the return leg which was okay, but a tad more hilly on a bike than in a car.
As you can see; slowly, slowly, catchee monkey.
Onwards and upwards. Huzzah!
