Kestevan
Last of the Summer Winos
- Holmfirth.
I managed to break my seatpost on the way home. It snapped off about 20mm above the clamp and made the remaining 5 miles rather interesting to say the least, I may even have swore a couple of times.
Of course the post was then stuck in the frame, and no amount of pulling on the carbon shards with pliers would free it at all, at this point there was definately some swearing.
I checked the net for a recommended method of removal, and the best bet seemed to be to take a hacksaw blade and cut through the sides of the post in 2 or 3 places, then crush the post with pliers and pull out.......
This was duly attempted; the post cut through and crushed with no problems. Then the fun started. The Trek seat-tube is oversize for most of its length, and then narrows for a couple of inches near the clamp. I'd managed to free the post just enough for it to free up at the narrow section. When I moved the pliers the post slipped back into the frame, disappearing completely. Cue swearing.
No amount of prodling about in the tube, turning the bike upside down, and/or swearing has managed to extract the seatpost. I suspect the crushed tube has expanded again, sealing itself into the seat-tube.
I've left it where it is, and fitted a spare seat-post for now. Seams OK other than a rattling noise. I suspect the only way to remove it will be to take the BB out, and hacksaw the tube into 20mm sections and remove in pieces.
I have a sneaking suspicion that this process may involve considerably more swearing.
