thank you all for the replies
The Bike was £2500 its a Topstone 105 and I just feel I'm being fobbed off by them. they clearly hadn't PDi, d it properly as several bolts were not done up correctly. it was a brand new bike so I was amazed they were taking links out the chain. ive tried by using the trim mechanism and it does give a bit of relief in some gears but certainly makes a racket in big/big &small/small. at one point they were bending the from derailleur with a pair of pliers.
I feel your pain. I've been through the same experience twice recently.
I bought a new Cube Axial last May via the net. They made me wait a few days before sending it in order to do the PDI. It had awful gear related problems - grinding, jumping, and chain rub. They told me to send it back for sorting, but that would have cost me £70 in carriage for there and back, and I had lost confidence. I took it to the local bike shop who are Cube dealers, but they refused to help, saying I should send it back.
I examined it myself. I found the incorrect front derailleur fitted and incompatible with the shifter. It was an 8 speed bike with a 6 speed chain fitted. The teeth on the chainset were damaged.
I went back to the LBS and part exchanged it for a Trek Domane. I left the shop as they were closing; on the way home, the first time I applied the brake, they was a terrible racket, the brake track was detached from the wheel. I got it home and found deep scratches on the top tube that hadn't been there the previous day when I viewed it. So that went back too.
Then in July came a Trek Emonda. It rattled terribly, so that went back. They diagnosed cable slap inside the frame, told me that was usual and I'd have to live with it. The gears were not good either.
By this time, I was pretty pissed off, so I took to looking it over myself. The spacer behind the cassette was missing causing the rattle and gear shift problems. I got a spacer from the supplying dealer and fitted it, but then I couldn't get the gears to work properly. They had given a spacer of the incorrect thickness. Vowing to never go back, I got the correct spacer from elsewhere and fitted that. Better but still not right. I then found the derallieur hanger screws to be loose. Better still but not right. The derailleur alignment looked incorrect to my eye so I fitted a new hanger, indexed the gears which made a big improvement. Chain rub was still an issue at the front, so I then set about that. The derailleur was too low, angled incorrectly. The cable was fitted to the derailleur in an incorrect way meaning that it didn't pull correctly. Having fixed all this for my self, I finally have a new bike that rides as it should.
My other half also bought a new bike, from a different shop. The next day a rear puncture produced a fountain of slime. The tyre compound was unbelievable soft, so new tyres and tubes were fitted to go slime-free. A few days after that on a ride, the front wheel collapsed, the rear wheel was also very poor. That was handled by that dealer very well who actually apologised unprompted for not picking these dangerous defects up on the PDI.
My advice is not to give up on the bike as I did with my Cube, but be determined to sort the bike out yourself. The kit is not all crap, it's just that in my experience some dealers are.
Good luck friend.
