DustBowlRefugee
- Sussex, England
Next silly question for my build. Brakes? V-Brakes or cantilever?
Thanks
Mark
Thanks
Mark
Could you use a travel agent (cam device) to make standard Vs work with STIs?
papercorn2000 said:Could you use a travel agent (cam device) to make standard Vs work with STIs?
Or you could just go for discs!
jpembroke said:I've tried Mini-Vs and they lasted all of one ride before I ditched them. You have to run them so close to rim that you can't release the cable from the straddle thingy in order to get the wheel out. Very frustrating. I have never used travel agents so can't comment on them. I think I'll stick to my trusty Tektro Oryx (I swapped stock straddle cable for old school yoke and wire for improved mechanical advantage (thanks Sheldon)).
rjeffroy said:There is a good picture here (click on it for a large view)
The straddle cable (which runs between the brake arms) is held in place by the little screws so that the triangular yoke cannot move on the cable. The cable routes underneath them.
