stuee147
- north ayrshire
why is it that no matter how many times i try to set up brakes no matter weather they are calliper brakes or v brakes. i set them up pulling the cables threw as best i can then i still need to use the little cable adjuster on the brake leaver and the brake to get the brakes to work...
am i missing a trick here i see bikes with working brakes that haven't had them bits wound out to tension the cable, so how do you get the tension in the first place, there has to be a trick to it or is it just me ????
am i the only one that cant get the tension lol ???
stuee
stuee
