BristolScouse
Regular
- Bristol, UK
Is it possible to upgrade the braking system on a Giant TCX1 from the block brakes to disc without too much expense or hassle?
greati'll have to look into that. if they do tho, is it an expensive transition?
+1, but also correct set up as well makes a tremendous difference IME.If you're trying to improve brakes, the answer is almost always Koolstop Salmon pads.
No not yet. Ive got my arm in a cast atm. As soon as its off im getting measured up then making the final decision. tbh i cant make a a decision between the Boardman (cant stand Halfords and i know if i get any problems with frame or forks im gunna have to wait an enternity to get it replaced) or the Gaint TCX1 or Gaint Escape RX disc. Im a big fan of disc breaks, but also like the TCX1 because it light and has the dummy brakes on the straight part of handle bars. My riding is probably 90-95% road and the rest cycle paths (mainly the Strawberry Line) If youve any suggestions they would be appreciatedHave you got this bike yet? I've had a quick mooch at your postings but can't decide TBH.
If not there are loads of other bike options that do have discs, THIS for example and it's far bit cheaper too.
Or THIS is in the same price range as the Giant, and Tricross always seems to be well reviewed.
There are loads to go at, just look at Evans for a start to see your options. That last link is filtered by mechanical discs as well for you![]()
