Brake recommendations, please.
DCBassman
Hopefully, today sees the arrival of the new brake lever/shifters for the Revell mixte. They should work fine with the Weinmann 730s currently fitted. However, if that's not the case, what are my options for fitting something dual-pivotey? Presume long drop as bike was originally 27x1.25 and now wearing 700c.
Would rather not have to do any frame mods but if I do, I do...
biggs682
Northamptonshire
Have a look at tektro range as they offer long drop and nutted type and try some koolstop pads
Gunk
Oxford
I’ve used an old set of Shimano 600’s or EX100’s both work like modern Shimano calipers. Another option would be an old pair of Campagnolo dual pivot calipers.
figbat
Former slippery scientist
Dia compe 806 dual pivot cover 57-75 mm.
I have one of these on my Dawes Kingpin - works very well (a lot better than the Weinmann single pivot that was on there). You can pick them up new for £15 but beware that they have no quick-release mechanism on the cable, making wheel removal a bit more involved.
si_c
Wirral
Probably looking at something like the Tektro R539s, long drop dual pivots, mechanical advantage will be no better than the Weinmanns though, so if you can get them working that would be your best bet.
All uphill
Still rolling along
Somerset
I have put Tektro 539s on two bikes. They do the job, but aren't, to my mind, as reassuring as short drop brakes, v-brakes or discs.
