cheadle hulme
- Llandudno
Shimano 105 rear brake and STI on Jamis Quest, only 1000 miles or so.
The rear brake has been "sticking" and therefore not returning fully when released. This means the lever is not tensioned and has c10mm of play. This makes it rattle.
I thought the caliper was gummed up, so today stripped it down and full regrease. Remounted caliper and returns fully open no problems (without cable).
Lubed the cable inners and checked cable was freely moving - all fine.
Reconnected cable expecting it to be fine, but still it sticks. I can pull the blocks out by another 5 mm either side after releasing the brake.
Shimano tech documents aren't much use.
Anyone got any ideas?
(well it is P&L) I can get on with anyone (nearly
