jiggerypokery
- Solihull
Any tips on adjusting the front Planet X brake - I can't seem to get it to return to centre properly or get the gapping right between rim & pad.
Didn't have this problem with my SRAM Force brakes.
The tip's don't seem to be working for me!
Tips on fitting the calipers:Mount the brake as centrally as possible using the main frame securing allen bolt.
The small allen key screw located in the central barrel which secures down on to the central pivot bolt is to assist in centring the caliper arms once the main securing bolt has been tightened.
There's also a small allen key grub screw on one of the caliper arms which tightens on to the main spring. Once the caliper has been centred using the main mounting bolt, the small allen grub screw can be used to 'fine-tune' the adjustment. By tightening it up, the tension on the spring will be increased and that caliper arm will move away from the rim. Loosen it off and the tension is released and the caliper arm will move towards the rim. It's very clever and kept some of us amused for hours.
Thanks - Stu
Thanks - Stu
