Brake Cables
sidevalve
If you just want to replace old for new using new levers and new cables then no problem. If you're just replacing the cables [and removing the "extra" levers from the old ones] then the new ones should still fit ok.
Just check the shape of the cable nipple matches and all should be well.
Chris S
Birmingham
Poundland (in Birmingham) have front inner brake cables at the moment. I don't think they're much more than that anyway.
02GF74
universal brake cables come with two different nipples at each end - one for road bike brakes (top), t'other for mtb (lower). you cut off the one that you do not need for fitting.
