nickg
- Colchester, Essex
Hi, recently had a new set of brake blocks fitted to my road bike. What's the best was to bed these in as the rear brake is pretty much non existent?
Do you mean brake pads, for disc brakes?
In my experience, brake blocks for rim brakes work straight from the start with no bedding in.
Did you only change the rear set? Maybe the pads are a nasty compound that just doesn't have much bite? What make are the new pads?
The only issue with rim brake blocks is the mould release agent on the surface. A few dabs of the brake will remove this and you are good to stop.
A couple of good autocorrect words in there - could confuse a newbie.I've never had new brake blocks cause a problem, but if they're working well prior to wearing out I always replace with identical blacks and decrease them with brake cleaner prior to fitting. I also clean the rim, dress with 1500 grit, and clean again.
For interests sake for the more in the know on such matters, they look like Clarks Elite Road Brake blocks Amazon product ASIN B07QS33XHGView: https://www.amazon.co.uk/Clarks-Replacement-Triple-Compound-Shimano/dp/B07QS33XHG
