I intend to bleed the brakes on my Cube (shimano M455). I have been reading up on the process. Can anyone explain why the new fluid is syringed in from the caliper end? Wouldn't is make more sense to use the same process as a car? Attach a tube to the caliper bleed nipple, making sure the bottom is immersed in a container of fluid. Open the bleed nipple, and use the brake lever to pump the new fluid through.Keep the master reservoir topped up via the screw in syringe.
I would be thanks
Martin
I would be thanks
Martin
